Introduction
Step by step instructional guide to replacing Spin Master Hatchimal Draggle speaker. Before getting started, fur and wing removal is required.
Turn the Hatchimal on its side to locate the clip holding the wing place.
  • Turn the Hatchimal on its side to locate the clip holding the wing place.
Ajouter un commentaire
Using the plastic opening tool, push in on the purple clip.
  • Using the plastic opening tool, push in on the purple clip.
Pull the wing off of the hatchimal.
  • Pull the wing off of the hatchimal.
  • The wing should come off with little resistance.
Turning the Hatchimal Upside down, locate the zip-tie holding the fur on. Cut the zip-tie with scissors.
  • Turning the Hatchimal Upside down, locate the zip-tie holding the fur on.
  • Cut the zip-tie with scissors.
Lift the fur up as far as you can with little resistance. Lift the fur up as far as you can with little resistance.
  • Lift the fur up as far as you can with little resistance.
Use the spudger tool to push up on the black clip to free it. Pull the clip out. Pull the clip out.
  • Use the spudger tool to push up on the black clip to free it.
  • Pull the clip out.
Lift fur up to reveal the next set of clips. Insert the Spudger tool to push up on the black clip to free it. Pull out the clip.
  • Lift fur up to reveal the next set of clips.
  • Insert the Spudger tool to push up on the black clip to free it.
  • Pull out the clip.
Lift the fur up and over the Hatchimals Head. Remove all six 12 mm Phillips Head screws.
  • Lift the fur up and over the Hatchimals Head.
  • Remove all six 12 mm Phillips Head screws.
Remove the plastic casing. Gently pull the yellow speaker cord from circuit board. There will be little resistance.
  • Remove the plastic casing.
  • Gently pull the yellow speaker cord from circuit board. There will be little resistance.
Remove all three 7mm Phillips Head screws. Remove the wheel base and the circuit board carefully not to damage the spring. Remove the wheel base and the circuit board carefully not to damage the spring.
  • Remove all three 7mm Phillips Head screws.
  • Remove the wheel base and the circuit board carefully not to damage the spring.
Push the 6 black fur clips up using the spudger tool to free the clips. Remove the fur completely.
  • Push the 6 black fur clips up using the spudger tool to free the clips.
  • Remove the fur completely.
Remove the two 7mm Philips Head screws holding the cover. Remove the two 7mm Philips Head screws holding the cover.
  • Remove the two 7mm Philips Head screws holding the cover.
Pull the speaker cover off. Proceed to remove speaker. Gently pull the speaker up using the cord.
  • Pull the speaker cover off.
  • Proceed to remove speaker. Gently pull the speaker up using the cord.
  • Speaker cover will come off with little resistance.
Hector Lopez
Membre depuis le 14/02/2018
243 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S1-G5, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S1-G5, Nance Spring 2018
USFT-NANCE-S18S1G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 44
