Introduction
The pump is used to take the water from the reservoir to the portafilter and steam wand.
First remove all six screws on the back panel. Remove the back panel, then set it aside. Remove the two screws holding the bottom panel in place.
  • First remove all six screws on the back panel.
  • Remove the back panel, then set it aside.
  • Remove the two screws holding the bottom panel in place.
  • Remove the bottom panel, then set it aside.
Where can I purchase a new pump from?
Tawana Nicole Simmons - Réponse
Pull the drip tray out, then set it aside. Turn the brew unit clockwise to unscrew. Pull the tube that goes into water reservoir out.
  • Pull the drip tray out, then set it aside.
  • Turn the brew unit clockwise to unscrew.
  • Pull the tube that goes into water reservoir out.
  • Slide the water reservoir out through the front of the barista to remove it.
  • Remove the top tray from the backside.
Ajouter un commentaire
Use an adjustable wrench to unscrew the connection tube between the pump and the boiler. Pull off both tubes connecting on each side of the pump. Remove the 3 electrical connectors from the pump.
  • Use an adjustable wrench to unscrew the connection tube between the pump and the boiler.
  • Pull off both tubes connecting on each side of the pump.
  • Remove the 3 electrical connectors from the pump.
Unscrew the two mounting bolts. Remove the pump unit from the Barista. Pull off the yellow end of the pump and unscrew T-shaped end.
  • Unscrew the two mounting bolts.
  • Remove the pump unit from the Barista.
  • Pull off the yellow end of the pump and unscrew T-shaped end.
  • See the links section of the device page for where to purchase a new pump.
I went to a link with a picture of the exact pump and model number. What came was a label free pump which is not and exact replacement. There is an o-ring which makes the seal between the tee and the pump so order a new one while you’re at it. The new pump is lacking the o-ring retention groove/recess in the tip of the pump’s brass output where the tee screws in. Since this is flat, the o-ring pinches out and sprays a fine stream out of the joint between the brass tee and the pump output stem. I will be calling them in the morning.
Model EA Type EAX5
https://www.amazon.com/gp/product/B00UCH...
macg - Réponse
7 autre(s) ont terminé cette réparation.
Alex
Membre depuis le 28/01/2011
335 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 4-42, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 membres
5 tutoriels rédigés
10 commentaires
What is meant by "See the links section of the device page for where to purchase a new pump"? Which device page on which website? Are you not able to just post the link? Which type/model of pump is required?
nick - Réponse
My son and I successfully replaced the pump, but it didn't go quite as easily as I'd thought. We could not get the hose that connects the boiler to the pump off. Thankfully, my clever son realized we could turn the portion of the pump that screws into the t-end to get the old pump off and new one on.....tricky, but doable. The new pump is a bit noisier than the last, but she pulls beautiful shots. Thanks so much for this guide!
Bananaslug - Réponse
Does anyone know the purpose of the hose that goes toward the back? not the one to the boiler but the other one that goes backward and down from the t-connector? it doesn't seem to be moving any water but the unit seems to work fine.
Michael2020 - Réponse
That's a return line I believe. So if there is water left it can drain back to the reservoir.
Chris Slater -
Here's a link to the pump on amazon that I just found
http://www.amazon.com/Ulka-EX5-Vibratory...
Josh Calvetti - Réponse
I was given a 10 year ols (approx.) Saeco Barista. It seems very loud when pumping.
I looked under the cover. everything looks new. A little bit of small debris in the corners, probably coffee.
Is the loud pump noise an indication of a worn pump or pump part? I don't think it's vibration. I think y=the pump mounts are intact.
Thanks
Ed
Lionel - Réponse
I have the same question. I received mine secondhand as well, and I have no experience with a new one to compare to. It seems to work, but I wonder if it's working well or just limping along. I think mine is ok just going by youtube videos: https://youtu.be/aBYmRHK9BJg and https://youtu.be/ju2GEvlE0hg
Harvey -
My Saeco Starbucks Barista machine still sounds like the pump is working, but no water is drawn up into the pump. I've tried priming the pump per the original instructions which tell me to open the steam wand while running the pump, but that does no good. And I've taken off the back for a look and everything appears to be properly connected, and, as I said, the pump sounds the same as always.
I assume this means the pump is shot, but I want to ask you all if that's the problem.
joe - Réponse
Try removing the filter and pushing water into the line with a turkey baster or similar. Or remove the back, hold the line towards the ceiling higher than the pump to allow air to escape and gravity to help. Tap the line and pump to make sure all air is out of the line. There still might be some inside the pump. The pump does not like to be dry.
Harvey -
Hopefully someone still looks at this page :) A friend of a friend was getting rid of this machine, and I accepted the donation. At first try, the pump wasn't pumping any water in. So I started full tear down of the machine and through couple stumbles and my own interest, took apart the portion of the pump that the water goes through. To my surprise, the inside was full of rust (not mineral). Furthermore, it seems that a lot of the components that comes in contact with the water is just steel (not stainless steel). Is it standard that these pump are made from steel component that are prone to rust, considering that the water for consumption flows right through them?
Thanks, Vasily
Vasily Romanov - Réponse
Voir les statistiques:
Dernières 24 heures : 7
7 derniers jours : 38
30 derniers jours : 151
Total : 26,450
