Introduction
The ready light is a simple LED that shows when the Barista has heated up to its needed temperature. This LED may burn out or its connectors may loosen.
Pièces
Aucune pièce nécessaire.
Unscrew the 6 screws from the back panel. Remove the back panel.
  • Unscrew the 6 screws from the back panel.
  • Remove the back panel.
Ajouter un commentaire
Locate the ready light. Gently push the fixture against the Barista wall. Pull the fixture straight up to release it.
  • Locate the ready light.
  • Gently push the fixture against the Barista wall.
  • Pull the fixture straight up to release it.
    • Note: The fixture works as a spring.
    • Note: The green cover from the front panel will "pop" off. Do not lose the green cover.
  • Disconnect the wire lead connectors.
  • Remove the ready light unit (fixture).
Replace the old LED with a new LED.
  • Replace the old LED with a new LED.
  • To put back, match the green cover to the slot of the LED fixture, then slide the fixture down against the barista wall.
David
Membre depuis le 28/01/2011
547 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-42, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 membres
5 tutoriels rédigés
Youth and sports for
Rich Ridout - Réponse
Ttuii addinsists
Where can I get a new LED bulb?
Paula - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 25
Total : 4,865
