Introduction
All that is needed to replace the battery is a screwdriver.
Pièces
Aucune pièce nécessaire.
Place the lamp LED side down on a clean workspace.
  • Place the lamp LED side down on a clean workspace.
  • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
Ajouter un commentaire
Gently pull the two halves of the lamp apart.
  • Gently pull the two halves of the lamp apart.
Locate the battery. Gently lift the battery from the device.
  • Locate the battery.
  • Gently lift the battery from the device.
Locate the clip attaching the battery pack to the circuit board.
  • Locate the clip attaching the battery pack to the circuit board.
  • Use tweezers to remove the portion of the clip attached to the battery.
  • Do not pull directly on the wires! They can easily be damaged.
Align the black wire of the new battery towards the center of the device.
  • Align the black wire of the new battery towards the center of the device.
  • Press down firmly on the clip to insure that it is properly connected.
  • Properly dispose of the Lithium-Ion Battery. Lithium Battery Disposal
Seat the battery in the orange component so that the short end of the battery pack is  touching the foam bumper.
  • Seat the battery in the orange component so that the short end of the battery pack is touching the foam bumper.
Anna
Membre depuis le 23/10/2014
454 Réputation
4 tutoriels rédigés
Équipe
Michigan Tech, Team 1-3, Lauer Fall 2014 Membre de l'équipe Michigan Tech, Team 1-3, Lauer Fall 2014
MTU-LAUER-F14S1G3
3 membres
5 tutoriels rédigés
please help in finding the life p04 battery,3.2v ,1500 mah,batch #20309
SHARATH PONUGOTI - Réponse
as my solar lights battery is dead..iam unable to find out whr i will get a new one
where to get the battery spare part?
johnkoisasi - Réponse
Please help me in finding PRO sunking battery 6.6v,1450mAh, Batch 30130.
Please contact me:stanleymayor944@yahoo.com
Stanley - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 34
Total : 961
