Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Surface Laptop Studio SSD Replacement
Ce dont vous avez besoin
  1. Surface Laptop Studio SSD Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
    Demander à FixBot
    Ajouter un commentaire
  2. Surface Laptop Studio SSD Replacement: étape 2, image 1 de 2 Surface Laptop Studio SSD Replacement: étape 2, image 2 de 2
    • Use a hair dryer to lightly heat the rubber feet to soften the adhesive securing them to the case.
    • Remove the two rubber feet on the lower case with an opening tool.
    • If you intend to reuse the rubber feet, take care not to warp, stretch, or tear them during removal.
    Demander à FixBot
  3. Surface Laptop Studio SSD Replacement: étape 3, image 1 de 1
    • Remove the two screws with a T3 Torx screwdriver.
    Demander à FixBot
  4. Surface Laptop Studio SSD Replacement: étape 4, image 1 de 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
    Demander à FixBot
  5. Surface Laptop Studio SSD Replacement: étape 5, image 1 de 2 Surface Laptop Studio SSD Replacement: étape 5, image 2 de 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
    Demander à FixBot
  6. Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: étape 6, image 1 de 2 Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: étape 6, image 2 de 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
    Demander à FixBot
  7. Surface Laptop Studio SSD Replacement, SSD: étape 7, image 1 de 1
    • After removing the devices battery, locate the SSD next to the mother board.
    Demander à FixBot
  8. Surface Laptop Studio SSD Replacement: étape 8, image 1 de 1
    • Remove the single 3 mm screw that secures the SSD.
    Demander à FixBot
  9. Surface Laptop Studio SSD Replacement: étape 9, image 1 de 1
    • Slide the SSD directly out of its socket.
    Demander à FixBot
5 autres ont terminé cette réparation.
Nate Ball
Membre depuis le 02/14/23
756 Réputation
5 tutoriels rédigés
Équipe
5 commentaires de tutoriel
Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
Luis Ruiz - Réponse Partager
I tried the SSD upgrade with two different WD products (1TB black and 1TB blue) and with both I had problems: Random blue screens and after some time, computed could not find the SSD anymore. Looks like it has something to do with drive consuming too much power but I am not sure. I am now back on original 256 GB SSD, since I can't find what is causing compatibility issues.
Pohistvo123 - Réponse Partager
Can you fit a full sized ssd or only the short ones?
Omega_o7 - Réponse Partager
You can fit a full-size (M.2 2280) SSD in the Suface Laptop Studio, but you won't be reusing the metal bracket that is there for the small SDD (2230 size). More info available here: https://dancharblog.wordpress.com/2021/1...
DoktorDread - Réponse Partager
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 59
30 derniers jours : 253
Total : 14,700
