Aller au contenu principal
Suzuki FA50 Moped Exhaust Pipe Replacement
Ce dont vous avez besoin
  1. Suzuki FA50 Moped Exhaust Pipe Replacement, Exhaust Pipe: étape 1, image 1 de 1
    • Use a #2 Phillips screwdriver to remove the heat shield from the muffler.
  2. Suzuki FA50 Moped Exhaust Pipe Replacement: étape 2, image 1 de 1
    • There are two 10 mm hex nuts attaching the muffler to the engine. Make sure you remove both of them before proceeding to the next step.
    • Use a 10 mm socket wrench to unscrew the two hex nuts.
  3. Suzuki FA50 Moped Exhaust Pipe Replacement: étape 3, image 1 de 1
    • Use a 12 mm socket wrench to unscrew the third and final hex nut that holds the muffler in place.
    • Make sure to support the muffler with your hand while removing this nut, otherwise it may just fall to the floor.
Un commentaire
Thanks you very much! Happy Fourth of July.
D4Tay - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 6,778
