Aller au contenu principal
Swann Doorphone Video Intercom Camera Replacement
Ce dont vous avez besoin
  1. Swann Doorphone Video Intercom Camera Replacement, Camera: étape 1, image 1 de 3 Swann Doorphone Video Intercom Camera Replacement, Camera: étape 1, image 2 de 3 Swann Doorphone Video Intercom Camera Replacement, Camera: étape 1, image 3 de 3
    • Flip the outdoor camera over so that the underside is facing up.
    • Remove the back cover by grabbing the sides of the camera and pulling towards your body.
  2. Swann Doorphone Video Intercom Camera Replacement: étape 2, image 1 de 2 Swann Doorphone Video Intercom Camera Replacement: étape 2, image 2 de 2
    • With the back cover of the outdoor camera off, press the first gray button, with blue wire underneath, down as shown in the picture.
    • While pressing the gray square button, remove the blue wire from the first opening under the button.
    • Be sure to remove the same color wire for the outdoor camera as was used for the indoor video intercom.
  3. Swann Doorphone Video Intercom Camera Replacement: étape 3, image 1 de 3 Swann Doorphone Video Intercom Camera Replacement: étape 3, image 2 de 3 Swann Doorphone Video Intercom Camera Replacement: étape 3, image 3 de 3
    • Remove the other wires using the same steps as the blue wire.
    • Using the JIS #0 screwdriver, remove the 2mm screws from the back plate.
    • Remove the back plate by pulling the plate away from the device.
  4. Swann Doorphone Video Intercom Camera Replacement: étape 4, image 1 de 2 Swann Doorphone Video Intercom Camera Replacement: étape 4, image 2 de 2
    • Using the JIS #0 screwdriver, remove the 1mm screws from behind the camera.
  5. Swann Doorphone Video Intercom Camera Replacement: étape 5, image 1 de 2 Swann Doorphone Video Intercom Camera Replacement: étape 5, image 2 de 2
    • Using one of the tweezers from the Precision Tweezers Set, gently place them around the wire connector attached to the camera.
    • Pull slowly in the direction of the cables until the connector is no longer attached.
  6. Swann Doorphone Video Intercom Camera Replacement: étape 6, image 1 de 2 Swann Doorphone Video Intercom Camera Replacement: étape 6, image 2 de 2
    • Remove the camera from the device.
Emily Stenke
Membre depuis le 02/14/18
555 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S2-G4, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
4 membres
5 tutoriels rédigés
15 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 12
Total : 637
