Aller au contenu principal
Swann Doorphone Video Intercom Microphone Replacement
Ce dont vous avez besoin
  1. Swann Doorphone Video Intercom Microphone Replacement, Microphone: étape 1, image 1 de 3 Swann Doorphone Video Intercom Microphone Replacement, Microphone: étape 1, image 2 de 3 Swann Doorphone Video Intercom Microphone Replacement, Microphone: étape 1, image 3 de 3
    • Flip the monitor of the Swann Doorphone Video Intercom over so that the underside is facing up.
    • Remove the six 2 mm corner screws from the back plate of the monitor using the JIS #0 screwdriver.
  2. Swann Doorphone Video Intercom Microphone Replacement: étape 2, image 1 de 2 Swann Doorphone Video Intercom Microphone Replacement: étape 2, image 2 de 2
    • Once the screws are removed, grip the black back plate of the monitor and remove from the monitor.
    • The back plate will still be connected to the monitor with a cord of wires that should not be removed.
  3. Swann Doorphone Video Intercom Microphone Replacement: étape 3, image 1 de 3 Swann Doorphone Video Intercom Microphone Replacement: étape 3, image 2 de 3 Swann Doorphone Video Intercom Microphone Replacement: étape 3, image 3 de 3
    • Using the precision tweezers, grab the sides of the white connector at the bottom of the green board.
    • Pull the white connector towards you to disconnect the board.
  4. Swann Doorphone Video Intercom Microphone Replacement: étape 4, image 1 de 3 Swann Doorphone Video Intercom Microphone Replacement: étape 4, image 2 de 3 Swann Doorphone Video Intercom Microphone Replacement: étape 4, image 3 de 3
    • Grip the other end of the white connector cable towards the base of the black microphone.
    • Pull gently towards your body to remove the microphone.
Emily Stenke
Membre depuis le 02/14/18
555 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S2-G4, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 341
