Aller au contenu principal
TI-36X Pro Front Cover Replacement
Ce dont vous avez besoin
  1. TI-36X Pro Front Cover Replacement, Back Cover: étape 1, image 1 de 2 TI-36X Pro Front Cover Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the calculator's protective cover.
    • Place the calculator face down.
  2. TI-36X Pro Front Cover Replacement: étape 2, image 1 de 2 TI-36X Pro Front Cover Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the six 6mm screws from the back of the case and place them to the side.
    • Start from the notches on the top edge and use your fingers or a prying tool to carefully pry the back cover from the calculator.
  3. TI-36X Pro Front Cover Replacement, Battery: étape 3, image 1 de 2 TI-36X Pro Front Cover Replacement, Battery: étape 3, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the two 7.5 mm screws holding the battery cover to the case.
    • Remove the battery cover without disconnecting either end of the blue wire.
    • Use your finger to move the battery cover to the side.
  4. TI-36X Pro Front Cover Replacement: étape 4, image 1 de 1
    • Use the flat side of a spudger to remove the battery by lifting the bottom edge.
    • When inserting a new battery, check the polarity (+ or -) and insert the new battery with the + side on top.
  5. TI-36X Pro Front Cover Replacement, Button: étape 5, image 1 de 1
    • After removing the battery, use a Phillips #00 screwdriver to take out the 4.5mm screw directly to the right of the solar panel.
    • Do not disconnect any wires or you will need to solder them back on.
  6. TI-36X Pro Front Cover Replacement: étape 6, image 1 de 1
    • Next, use a Phillips #00 screwdriver to remove the two screws located on each side of the striped ribbon between the two green circuit boards.
  7. TI-36X Pro Front Cover Replacement: étape 7, image 1 de 1
    • Be careful not to scratch the gold lines on the circuit board since it may damage the circuit.
    • Carefully chisel off the 11 circular pieces that connect the lower circuit board to the calculator.
    • When reassembling the calculator, glue the lower circuit board back in place by dabbing glue into the holes that you chiseled.
  8. TI-36X Pro Front Cover Replacement: étape 8, image 1 de 3 TI-36X Pro Front Cover Replacement: étape 8, image 2 de 3 TI-36X Pro Front Cover Replacement: étape 8, image 3 de 3
    • When removing the parts from the calculator be careful not to break any wires or ribbons. The solar panel, screen, and lower circuit board should remain connected throughout this guide.
    • Lift the top edge of the solar panel with a finger and slide it away from the circuit board to disconnect it from the calculator.
    • Carefully pry the screen out of the calculator with a prying tool or spudger.
    • Pry the lower circuit board from the calculator by inserting a prying tool between the base of the calculator and the circuit board.
  9. TI-36X Pro Front Cover Replacement: étape 9, image 1 de 1
    • Grab one of the top corners of the gray rubber button pad and peel it off of the buttons.
    • If you turn the calculator over, all of the buttons will fall out.
  10. TI-36X Pro Front Cover Replacement: étape 10, image 1 de 2 TI-36X Pro Front Cover Replacement: étape 10, image 2 de 2
    • Locate the button that needs replacement and lift it out of the calculator with tweezers.
    • If the buttons do fall out, use the second picture to put them back properly.
  11. TI-36X Pro Front Cover Replacement, Front Cover: étape 11, image 1 de 1
    • Empty the buttons into a bag or place them somewhere that they will not be lost.
    • Using a spudger, undo the 5 clips around the edge of the casing that connect the front cover to the calculator.
  12. TI-36X Pro Front Cover Replacement: étape 12, image 1 de 1
    • Pry the front cover off of the calculator with a prying tool from the bottom up.
2 autres ont terminé cette réparation.
Robert Sekerak
Membre depuis le 04/25/14
652 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-52, Amido Spring 2014 Membre de l'équipe Cal Poly, Team 11-52, Amido Spring 2014
CPSU-AMIDO-S14S11G52
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 12
Total : 1,737
