Introduction
For this guide you will remove the back cover, battery cover, and battery in order to replace the solar panel.
Ce dont vous avez besoin
Remove the calculator's protective cover.
Place the calculator face down.
Use a Phillips #00 screwdriver to remove the two 7.5 mm screws holding the battery cover to the case.
Use your finger to move the battery cover to the side.
To detach the solar panel, use a Phillips #00 screwdriver to remove the 4.5mm screw that connects the solar panel to the calculator.
Once the screw has been removed, you may lift the top of the black solar panel cover with your finger and gently pull away from the green circuit board.
3 autres ont terminé cette réparation.
