Aller au contenu principal
TI-84 Plus Silver Edition Backup Battery Replacement
Ce dont vous avez besoin
  1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: étape 1, image 1 de 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: étape 1, image 2 de 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: étape 1, image 3 de 3
    • Push firmly down on the tab located on the back of the calculator near the center.
    • Pull the tab up, lifting it off of the calculator and exposing the batteries.
  2. TI-84 Plus Silver Edition Backup Battery Replacement: étape 2, image 1 de 1
    • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
    • Push the positive (+) side of the batteries to remove them
  3. TI-84 Plus Silver Edition Backup Battery Replacement, Backup Battery: étape 3, image 1 de 1
    • Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
  4. TI-84 Plus Silver Edition Backup Battery Replacement: étape 4, image 1 de 1
    • Grab the plate and lift gently upward, to remove the backup battery cover.
  5. TI-84 Plus Silver Edition Backup Battery Replacement: étape 5, image 1 de 2 TI-84 Plus Silver Edition Backup Battery Replacement: étape 5, image 2 de 2
    • Wedge the small plastic opening tool under the backup battery in the gap to the left of the backup battery.
    • The backup battery is an SR44SW coin cell battery. You can also replace it with a size 357/303 or LR44 battery.
    • Push gently downward until the backup battery pops out.
17 autres ont terminé cette réparation.
Agustin
Membre depuis le 10/20/13
1 028 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-34, Amido Fall 2013 Membre de l'équipe Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 membres
6 tutoriels rédigés
9 commentaires
My son's TI 84 Plus C has a rechargeable battery with a little cord attached to it which is significantly different from the AAA's shown in this Guide!
annualgain - Réponse
Because it's a completely different calculator.
Ozan Munsuz -
Muy instructivo e ilustrativo que permite fácilmente la operación de cambio de bacteria.
Andres Guaty - Réponse
Do NOT replace the back up battery and the main batteries at the same time! If you do, you will lose all of the calculator’s memory.
Alexander Dombroski-21 - Réponse
Too late…….. I had about 13000 bytes of programs
Aaron Rueppel -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 67
30 derniers jours : 280
Total : 65,777
