Introduction
Replace the cracked or damaged screen of TI-Nspire Calculator to enable the display for more efficient use of the device.
Place the calculator screen facing down with the back plate facing up.
  • Place the calculator screen facing down with the back plate facing up.
Ajouter un commentaire
With a #000 Philips screwdriver, remove the 6 x .286 inch screw drivers located at the top, middle, and bottom of the calculator.
  • With a #000 Philips screwdriver, remove the 6 x .286 inch screw drivers located at the top, middle, and bottom of the calculator.
Locate the latch toward the bottom of the calculator.
  • Locate the latch toward the bottom of the calculator.
Slide the latch to the right to release the keypad. At the same time, pull the keypad down.
  • Slide the latch to the right to release the keypad.
  • At the same time, pull the keypad down.
Locate and remove the screw near the bottom of the calculator on the front side.
  • Locate and remove the screw near the bottom of the calculator on the front side.
    • The screw is behind where the keyboard normally sits.
Now, turn the calculator over so the back plate faces up. Use the Plastic Prying Tool to carefully pry the back plate out at the bottom right corner. The prying order is arbitrary. The important part is for it to be sequential across the length of the calculator.
  • Now, turn the calculator over so the back plate faces up.
  • Use the Plastic Prying Tool to carefully pry the back plate out at the bottom right corner.
    • The prying order is arbitrary. The important part is for it to be sequential across the length of the calculator.
  • Repeat the prying step on the right side, moving along the perimeter of the calculator.
  • Repeat the prying step on the top right corner.
Use your hands to manually separate the now loosened back plate from the calculator.
  • Use your hands to manually separate the now loosened back plate from the calculator.
Remove the four batteries to help prevent electrical shorts in later steps.
  • Remove the four batteries to help prevent electrical shorts in later steps.
Remove the four 0.165 inch screws at the middle and bottom of the motherboard with the screwdriver.
  • Remove the four 0.165 inch screws at the middle and bottom of the motherboard with the screwdriver.
  • Use a Phillips #000 screwdriver to remove the two 0.349 inch screws at the top corners of the motherboard.
Holding the calculator with the motherboard face-up, gently press the screen up about 3/8 inch and towards the motherboard. Remove the motherboard and screen together and set aside.
  • Holding the calculator with the motherboard face-up, gently press the screen up about 3/8 inch and towards the motherboard.
  • Remove the motherboard and screen together and set aside.
Use a flathead screwdriver to gently pry the orange ribbon away from the screen.
  • Use a flathead screwdriver to gently pry the orange ribbon away from the screen.
What is the purpose of step 11 since you have already taken the screen off the calculator?
Sarah Taylor - Réponse
Alan Wong
Membre depuis le 26/09/2012
63 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-52, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 membres
11 tutoriels rédigés
Great guide! Just wondering where you found the replacement LCD? I've searched and searched the guide and the Internet and can't seem to locate them. Any help is greatly appreciated! Thanks!
Jeff Watkins - Réponse
replacing is not easy. there are no quick connectors. used nspires r cheap.
trogfield - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 19
Total : 5,692
