Aller au contenu principal
TP-Link MR3040 Wireless Router Disassembly
Ce dont vous avez besoin
  1. TP-Link MR3040 Wireless Router Disassembly, TP-Link MR3040 Wireless Router Disassembly: étape 1, image 1 de 1
    • First, open the case by prying off the bottom the same way you access the battery. Use a thumbnail on this side and the other side
  2. TP-Link MR3040 Wireless Router Disassembly: étape 2, image 1 de 2 TP-Link MR3040 Wireless Router Disassembly: étape 2, image 2 de 2
    • This is also how you install or remove the battery
  3. TP-Link MR3040 Wireless Router Disassembly: étape 3, image 1 de 1
    • First, use a small Philips head screwdriver - a 00 worked for me - and remove the two screws indicated by the ORANGE stars.
    • The four yellow stars indicate where you will be prying the TABS away
  4. TP-Link MR3040 Wireless Router Disassembly: étape 4, image 1 de 1
    • This is what it will look like taken apart. The white plate at the top of the picture is the plate you will be removing. The gray plate is where the circuit board sits. In this picture the circuit board is already removed.
    • NOTE that there are also tabs at the ends of the router, I noted one with a red X -- you don't need to worry about those, they slip off once you get the other tabs loose.
  5. TP-Link MR3040 Wireless Router Disassembly: étape 5, image 1 de 2 TP-Link MR3040 Wireless Router Disassembly: étape 5, image 2 de 2
    • The latch is on the white case. The tabs are on the gray case. You will be pushing the white latch AWAY from the gray tabs.
    • Put your flat blade to the OUTBOARD side of the white latch in the hole. Push INBOARD to pry it OFF of the tabs, pushing down through the hole at the same time in order to push the white case off. You'll want to hold the router by the gray if you can.
    • As you push the latch you'll obviously need to try to pry the two pieces apart like with your fingernail.
To reassemble your device, snap it back together. Bear in mind that if you remove the circuit board you'll need to align the power and other switch with their carriers in the gray case.
steve
Membre depuis le 08/01/16
1 385 Réputation
3 tutoriels rédigés
Un commentaire
it's so weird seeing a video I made being referenced by somebody. Lol it's nice to see that it helps someone!
hackeritalics - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 14
Total : 1,702
