Introduction
Removing the TRS-80 Color Computer's motherboard.
Pièces
Aucune pièce nécessaire.
Flip the computer over.
  • Flip the computer over.
  • Remove the two 24.1mm Phillips screws near the front of the case.
  • Remove the five 33.0 mm Phillips screws towards the back of the case.
Ajouter un commentaire
Carefully flip the computer right side up. Lift off the top half of the case.
  • Carefully flip the computer right side up.
  • Lift off the top half of the case.
Near the motherboard, gently pull the keyboard ribbon cable until it becomes free. Lift the keyboard out of the case.
  • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
  • Lift the keyboard out of the case.
Remove the nine 15.24 mm Phillips screws securing the motherboard in place. When removing the spring door, make sure to keep the door closed. When removing the spring door, make sure to keep the door closed.
  • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
  • When removing the spring door, make sure to keep the door closed.
Remove the 5 jumper cables from the motherboard. Once the jumper cables lift the motherboard up gently; it should lift out easily. Once the jumper cables lift the motherboard up gently; it should lift out easily.
  • Remove the 5 jumper cables from the motherboard.
  • Once the jumper cables lift the motherboard up gently; it should lift out easily.
2 autre(s) ont terminé cette réparation.
Andrew
Membre depuis le 23/01/2011
442 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-24, Maness Winter 2011 Membre de l'équipe Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 16
Total : 2,895
