Introduction
Use this repair guide when the shoulder buttons need to be replaced.
Ce dont vous avez besoin
Slide the battery out from under the brown wire-tape.
Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
Outil utilisé dans cette étape :Desoldering Pump$3.99
Carefully remove the solder between the shoulder buttons and the motherboard with the soldering sucker.
Presque terminé !
