Introduction
This guide will help you replace your faulty volume knob. This guide should only be looked at after completing the Disassembly Guide.
Pièces
Aucune pièce nécessaire.
Remove the screws that are holding the circuit board in place. Remove the screws that are holding the circuit board in place.
  • Remove the screws that are holding the circuit board in place.
Ajouter un commentaire
Pull the circuit board out to reveal the inside of the display. Pull the circuit board out to reveal the inside of the display.
  • Pull the circuit board out to reveal the inside of the display.
Remove the screws and the black piece that are holding the volume control knob in place. Remove the screws and the black piece that are holding the volume control knob in place. Remove the screws and the black piece that are holding the volume control knob in place.
  • Remove the screws and the black piece that are holding the volume control knob in place.
Pull the volume control knob from the outside and the white piece on the inside until they separate. Replace the volume knob with a new one to complete the repair.
  • Pull the volume control knob from the outside and the white piece on the inside until they separate.
  • Replace the volume knob with a new one to complete the repair.
To reassemble your device, follow these instructions in reverse order and follow the disassembly guide instructions in reverse order.
2 autre(s) ont terminé cette réparation.
Oliver Kunz
Membre depuis le 26/09/2012
107 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 2-61, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 2-61, Propen Fall 2012
CPSU-PROPEN-F12S2G61
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 3,231
