Aller au contenu principal
Texas Instruments TI-83 Plus Keyboard Mat Replacement
Ce dont vous avez besoin
  1. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Backup Battery: étape 1, image 1 de 2 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Backup Battery: étape 1, image 2 de 2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Keyboard Mat Replacement: étape 2, image 1 de 1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Keyboard Mat Replacement: étape 3, image 1 de 1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Back Case: étape 4, image 1 de 1
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Texas Instruments TI-83 Plus Keyboard Mat Replacement: étape 5, image 1 de 2 Texas Instruments TI-83 Plus Keyboard Mat Replacement: étape 5, image 2 de 2
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  6. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Motherboard & Screen: étape 6, image 1 de 2 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Motherboard & Screen: étape 6, image 2 de 2
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  7. Texas Instruments TI-83 Plus Keyboard Mat Replacement: étape 7, image 1 de 2 Texas Instruments TI-83 Plus Keyboard Mat Replacement: étape 7, image 2 de 2
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
  8. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Keyboard Mat: étape 8, image 1 de 2 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Keyboard Mat: étape 8, image 2 de 2
    • Remove light gray rubber keyboard mat.
    • Keep your calculator face down to ensure the individual keys do not fall out.
  9. Texas Instruments TI-83 Plus Keyboard Mat Replacement: étape 9, image 1 de 1
    • Clean the contacts on the keyboard with a soft cloth.
corey
Membre depuis le 10/02/12
11 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 18-37, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 4,596
