Introduction
In this guide we will be replacing the backup battery for the TI-92.
The first step to any repair operation is to remove the front cover. Grab the back of the calculator with one hand and the cover with the other. Pull the cover off from one of the sides for easy removal.
  • The first step to any repair operation is to remove the front cover.
  • Grab the back of the calculator with one hand and the cover with the other.
  • Pull the cover off from one of the sides for easy removal.
Ajouter un commentaire
Orientate the calculator with the top facing towards you. Slide the locking tab,found on the top part of the calculator, to the unlock position.
  • Orientate the calculator with the top facing towards you.
  • Slide the locking tab,found on the top part of the calculator, to the unlock position.
"Locking Tab" To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
  • "Locking Tab"
  • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
  • Then with the front of the calculator facing down, pull up on the back cover.
  • The calculator should now be orientated with the front facing down, as shown in picture 2.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Before removing the backup battery make sure your AA batteries are installed so that there is no loss of information.
  • Before removing the backup battery make sure your AA batteries are installed so that there is no loss of information.
  • Using a #00 Philip Screwdriver remove the 19mm screw located near the center of the back of the calculator on the panel with words "Test Access"
Remove the screw and lift the panel to access battery.
  • Remove the screw and lift the panel to access battery.
The backup battery can now be seen underneath a small metal cover held by a screw. Using the same screwdriver, unscrew the 4.6mm screw located under the panel and left of the backup battery.
  • The backup battery can now be seen underneath a small metal cover held by a screw.
  • Using the same screwdriver, unscrew the 4.6mm screw located under the panel and left of the backup battery.
Remove the metal cover keeping the backup battery in place. Remove the metal cover keeping the backup battery in place. Remove the metal cover keeping the backup battery in place.
  • Remove the metal cover keeping the backup battery in place.
Use an Ipod Opening Tool or a similar tool to pull up on the right side of the backup battery. The battery should pop out of position.
  • Use an Ipod Opening Tool or a similar tool to pull up on the right side of the backup battery.
  • The battery should pop out of position.
After the battery has been tilted out of its socket, simply remove it with your hands. After the battery has been tilted out of its socket, simply remove it with your hands.
  • After the battery has been tilted out of its socket, simply remove it with your hands.
2 autre(s) ont terminé cette réparation.
Daniel Maldonado
Membre depuis le 14/04/2010
177 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 15-51, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 19
Total : 4,010
