Introduction
The Sharper Image Literati Tablet's Keyboard may need to be replaced due to wear on the keys within a few years of purchase. The Keyboard replacement for The Sharper Image Tablet can be done in approximately half an hour to forty five minutes with moderate difficulty level in nineteen steps. Keyboard replacement for The Sharper Image Literati Tablet can help your device look new once more.
Wedge plastic spudger tool between the back panel and the body of device.
  • Wedge plastic spudger tool between the back panel and the body of device.
  • Pry apart the back panel and the device.
Ajouter un commentaire
Desolder the battery wires from the circuit board.
  • Desolder the battery wires from the circuit board.
Warm the battery with a hair dryer.
  • Warm the battery with a hair dryer.
  • Be carful not to over-heat the battery, this could cause the battery to ignite.
Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
  • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
  • Do not bend or puncture the battery. Work slowly and carefully.
Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
  • Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use a Phillips #00 screwdriver to remove three  4 mm screws from the circuit board containing the headphone jack and power jack.
  • Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
Remove the circuit board.
  • Remove the circuit board.
Unclip ZIF clip from the chip and unplug ribbon cable.
  • Unclip ZIF clip from the chip and unplug ribbon cable.
Detach the peripheral edge with plastic wedge.
  • Detach the peripheral edge with plastic wedge.
  • This may require a little hard pulling.
Remove peripheral silver edge.
  • Remove peripheral silver edge.
Remove screws from the large metal shielding.
  • Remove screws from the large metal shielding.
Remove the silver backing plate and the adhered SD port chip.
  • Remove the silver backing plate and the adhered SD port chip.
Remove the 10 Phillips head 4.2 mm screws using PH#00 screwdriver from the key board chip.
  • Remove the 10 Phillips head 4.2 mm screws using PH#00 screwdriver from the key board chip.
Peal back the sensor array and keypad. Peal back the sensor array and keypad.
  • Peal back the sensor array and keypad.
Spencer Dodder
Membre depuis le 21/03/2018
533 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S5-G4, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S5-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G4
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 42
