Introduction
This guide will help individuals replace the fingerprint reader for the first generation ThinkPad X1 Carbon. It is highly recommended to have the replacement reader ready for installation prior to opening the device.
Unscrew the seven screws located on the back of the device.
  • Unscrew the seven screws located on the back of the device.
Ajouter un commentaire
Slide the plastic opening tool along the edge of the device to separate the keyboard tray.
  • Slide the plastic opening tool along the edge of the device to separate the keyboard tray.
Flip the device over and open it to lift the keyboard tray from the body of the device.
  • Flip the device over and open it to lift the keyboard tray from the body of the device.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use the plastic opening tool to gently release the ribbon cable attached to the keyboard.
  • Use the plastic opening tool to gently release the ribbon cable attached to the keyboard.
  • You may now place the device off to the side. The rest of the repair takes place on the keyboard tray.
Locate the Fingerprint Reader and metal frame on the left side of the keyboard tray.
  • Locate the Fingerprint Reader and metal frame on the left side of the keyboard tray.
Unscrew the two silver screws to remove the metal frame.
  • Unscrew the two silver screws to remove the metal frame.
Remove the ribbon cable connected to the board.
  • Remove the ribbon cable connected to the board.
  • Remove and Replace the Fingerprint Reader board and metal frame.
  • This connection does not have a lock, please pull the ribbon away from the board. Do not attempt to lift the connection.
Kirby Raines
Membre depuis le 23/01/2018
627 Réputation
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 27
Total : 53
