Aller au contenu principal
ThinkPad Yoga 12 SSD Replacement
Ce dont vous avez besoin
  1. ThinkPad Yoga 12 SSD Replacement, Screws: étape 1, image 1 de 3 ThinkPad Yoga 12 SSD Replacement, Screws: étape 1, image 2 de 3 ThinkPad Yoga 12 SSD Replacement, Screws: étape 1, image 3 de 3
    • Remove the ten Phillips screws using a Philips 00 screwdriver
  2. ThinkPad Yoga 12 SSD Replacement, Prying: étape 2, image 1 de 2 ThinkPad Yoga 12 SSD Replacement, Prying: étape 2, image 2 de 2
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 SSD Replacement, Lift off cover: étape 3, image 1 de 1
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: étape 4, image 1 de 2 ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: étape 4, image 2 de 2
    • Carefully remove two Phillips screws with a Phillips 0 screwdriver
    • Static sensitive components!
  5. ThinkPad Yoga 12 SSD Replacement: étape 5, image 1 de 2 ThinkPad Yoga 12 SSD Replacement: étape 5, image 2 de 2
    • Gently grab the plastic tab. Lift and pull the SSD assembly out of the computer
  6. ThinkPad Yoga 12 SSD Replacement, Remove enclosure: étape 6, image 1 de 2 ThinkPad Yoga 12 SSD Replacement, Remove enclosure: étape 6, image 2 de 2
    • Remove the 4 identical Phillips screws with a Phillips 00 screw driver (they are on both sides).
  7. ThinkPad Yoga 12 SSD Replacement, Done!: étape 7, image 1 de 2 ThinkPad Yoga 12 SSD Replacement, Done!: étape 7, image 2 de 2
    • Carefully remove the SSD enclosure.
    • Note: The SSD enclosure is made of thin metal. It can be easily deformed. Be careful when removing from the SSD.
6 autres ont terminé cette réparation.
[deleted]
Membre depuis le 03/18/18
1 324 Réputation
3 tutoriels rédigés
Un commentaire
Almost perfect instructions. I do recommend removing the active pen first. Also it's a good idea to remind people that the active pen holder is screwed to the case cover from the inside and will come out as part of the cover.
Dani Deitch - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 19
Total : 4,868
