Introduction
This guide will show you how to replace the connection port for the pedals.
Remove the black 10mm using a JIS #1 screw driver.
  • Remove the black 10mm using a JIS #1 screw driver.
  • There are 12 screws.
  • Two of the screws are deep inside the device you might need to use a slim screwdriver.
  • In the picture you see a plastic opining tool instead of screw driver because we did not have our screw driver when we were taking the picture.
Ajouter un commentaire
Kits de RAM Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits de RAM Mac
Obtenez plus de mémoire sur votre Mac.
Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws. Gently pull apart both halves of device to access inside.
  • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
  • Gently pull apart both halves of device to access inside.
Using a small plastic opening tool, gently pry up the white connector that connects the pedals to the board. By pulling up on both ends of the port you will be able to pull out the port to remove it.
  • Using a small plastic opening tool, gently pry up the white connector that connects the pedals to the board.
  • By pulling up on both ends of the port you will be able to pull out the port to remove it.
Mario Nunez
Membre depuis le 18/10/2017
301 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S1-G33, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
4 membres
5 tutoriels rédigés
I just need to know where to get a replacement USB cable from ( the USB to the circular end part).
TheComfyCompie - Réponse
I need to know what USB cable connects the round cable end on the steerwheel to the Xbox one
Susan Witter - Réponse
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 89
Total : 552
