Aller au contenu principal
TiVo Series 2 TCD540080 Cooling Fan Replacement
Ce dont vous avez besoin
  1. TiVo Series 2 TCD540080 Cooling Fan Replacement, Removal of TiVo Series 2 TCD540080 Case: étape 1, image 1 de 1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Cooling Fan Replacement: étape 2, image 1 de 1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Cooling Fan Replacement: étape 3, image 1 de 2 TiVo Series 2 TCD540080 Cooling Fan Replacement: étape 3, image 2 de 2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Cooling Fan Replacement, Cooling Fan: étape 4, image 1 de 1
    • The fan is held in by four T15 screws on the rear of the device.
  5. TiVo Series 2 TCD540080 Cooling Fan Replacement: étape 5, image 1 de 2 TiVo Series 2 TCD540080 Cooling Fan Replacement: étape 5, image 2 de 2
    • Take the wound red and black wires coming from the fan and follow them back to the logic board.
    • Unplug the connector from the motherboard.
  6. TiVo Series 2 TCD540080 Cooling Fan Replacement: étape 6, image 1 de 2 TiVo Series 2 TCD540080 Cooling Fan Replacement: étape 6, image 2 de 2
    • Pull the fan towards the front and out of the TiVo unit.
Svyatoslav Markeyev
Membre depuis le 04/16/10
135 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 33-79, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 5,237
