Pièces
Aucune pièce nécessaire.
Power down the TiVo and detach the power cable from the rear of the unit.
  • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
Ajouter un commentaire
Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
Lift up and pull back the outer casing towards the rear of the unit. Lift up and pull back the outer casing towards the rear of the unit.
  • Lift up and pull back the outer casing towards the rear of the unit.
I have the TiVo Series 2 model TCD746500 and the procedure for replacing a fan on my model is almost identical to the procedure described here, with one significant difference at this step: first pull/slide the outer casing back towards yourself and only thereafter pull it up.
Oscar Abraham Jaeger - Réponse
Disconnect the power to the hard drive.
  • Disconnect the power to the hard drive.
Grab the hard drive data cable from both sides of the connector and unplug it from the hard drive.
  • Grab the hard drive data cable from both sides of the connector and unplug it from the hard drive.
    • Use extreme caution when unplugging connector and do not disconnect the data cable by pulling on the cable itself.
Unscrew the two screws on the case of the hard drive with a T10 screwdriver.
  • Unscrew the two screws on the case of the hard drive with a T10 screwdriver.
  • Pull the hard drive up and out of the TiVo unit.
Unscrew the four screws, shown in the picture, with a T-10 screwdriver.
  • Unscrew the four screws, shown in the picture, with a T-10 screwdriver.
  • Remove the hard drive from the case.
2 autre(s) ont terminé cette réparation.
Svyatoslav Markeyev
Membre depuis le 16/04/2010
135 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 33-79, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 13
Total : 6,658
