Pièces
Aucune pièce nécessaire.
Power down the TiVo and detach the power cable from the rear of the unit.
  • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
Ajouter un commentaire
Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
Lift up and pull back the outer casing towards the rear of the unit. Lift up and pull back the outer casing towards the rear of the unit.
  • Lift up and pull back the outer casing towards the rear of the unit.
I have the TiVo Series 2 model TCD746500 and the procedure for replacing a fan on my model is almost identical to the procedure described here, with one significant difference at this step: first pull/slide the outer casing back towards yourself and only thereafter pull it up.
Oscar Abraham Jaeger - Réponse
Carefully remove the ribbon cable from the power supply. Hold the ribbon on both sides and pull up. Carefully remove the ribbon cable from the power supply. Hold the ribbon on both sides and pull up.
  • Carefully remove the ribbon cable from the power supply. Hold the ribbon on both sides and pull up.
Disconnect the hard drive power cable. Firmly grip the white power connector and pull away from the hard drive.
  • Disconnect the hard drive power cable. Firmly grip the white power connector and pull away from the hard drive.
  • Do not pull on the power cables when disconnecting power connector.
Rotate the device 180 degrees and remove the two T10 screws from the power supply board.
  • Rotate the device 180 degrees and remove the two T10 screws from the power supply board.
Remove the four plastic standoffs. Use pliers to squeeze the plastic pieces on the head together. Carefully press down on the standoff and pull up on the power supply.
  • Remove the four plastic standoffs.
  • Use pliers to squeeze the plastic pieces on the head together. Carefully press down on the standoff and pull up on the power supply.
Lift the power supply out of the unit. Do not touch any circuit elements or capacitors on the power supply, as they may hold a charge after the unit has been shut off.
  • Lift the power supply out of the unit.
  • Do not touch any circuit elements or capacitors on the power supply, as they may hold a charge after the unit has been shut off.
2 autre(s) ont terminé cette réparation.
Svyatoslav Markeyev
Membre depuis le 16/04/2010
135 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 33-79, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 4,789
