Introduction
The back cover on the TomTom ONE is likely to chip or break due to excessive use. The mount guides can get worn down and not function properly. This guide will help you to replace it.
Ce dont vous avez besoin
Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
Outil utilisé dans cette étape :Tweezers$4.99
Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
2 autres ont terminé cette réparation.
