Aller au contenu principal
TomTom ONE Speaker Replacement
Ce dont vous avez besoin
  1. TomTom ONE Speaker Replacement, Speaker: étape 1, image 1 de 1
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Speaker Replacement: étape 2, image 1 de 2 TomTom ONE Speaker Replacement: étape 2, image 2 de 2
    • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Speaker Replacement: étape 3, image 1 de 1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Speaker Replacement: étape 4, image 1 de 1
    • Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  5. TomTom ONE Speaker Replacement: étape 5, image 1 de 2 TomTom ONE Speaker Replacement: étape 5, image 2 de 2
    • Take the spudger and pry out the speaker.
    • When taking out the speaker, the entire plastic shock mounting casing will come out.
2 autres ont terminé cette réparation.
Becca
Membre depuis le 04/16/10
211 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-7, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 7-7, Maness Spring 2010
CPSU-MANESS-S10S7G7
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 9,523
