Introduction
The TomTom touch screen can stop working or stop responding altogether. This guide will show how to properly remove it.
Position the device so that the underside is facing up. Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
  • Position the device so that the underside is facing up.
  • Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
  • Firmly grab the EasyPort Mount and remove it.
  • If it does not dislodge easily, gently twist the EasyPort Mount, applying increasing pressure until it does.
Ajouter un commentaire
Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top. Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
  • Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top.
  • Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
Flip the device over so that the screen is facing up. Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
  • Flip the device over so that the screen is facing up.
  • Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
  • It may be easier to start at one of the corners.
  • The gold ribbon cable connecting the screen to the motherboard is fragile and tears easily.
  • This specific device's ribbon cable is torn.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Carefully slide the screen forward, revealing the lower portion of the motherboard. Remove the 3.6mm screw using the JIS #00 Screwdriver.
  • Carefully slide the screen forward, revealing the lower portion of the motherboard.
  • Remove the 3.6mm screw using the JIS #00 Screwdriver.
  • Rotate the device 180 degrees, carefully slide back the screen, and remove the remaining two screws.
Disconnect the battery and speaker cables. Unlatch the motherboard from the case. Unlatch the motherboard from the case.
  • Disconnect the battery and speaker cables.
  • Unlatch the motherboard from the case.
Wedge a spudger between the  white plastic latch and the black connection port, disconnecting the gold ribbon cable. Slide the gold ribbon cable out of the port.
  • Wedge a spudger between the white plastic latch and the black connection port, disconnecting the gold ribbon cable.
  • Slide the gold ribbon cable out of the port.
Maybe add the picture of the motherboard and screen separated
Dakota Baker - Réponse
Use a plastic opening tool to unlatch the screen from its case. We recommend starting on the side with the gold ribbon cable as the latches are more tricky. Unlatch the screen corner by corner instead of an entire side at one time.
  • Use a plastic opening tool to unlatch the screen from its case.
  • We recommend starting on the side with the gold ribbon cable as the latches are more tricky.
  • Unlatch the screen corner by corner instead of an entire side at one time.
  • The tearing sound is the adhesive holding the screen to the case. It will re-stick when you put the screen together.
It may be smart to get rid of the first photo and add a photo with the screen and case separated
Jennifer Zakaria
Membre depuis le 18/01/2018
531 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S12-G2, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S12-G2, Banghart Winter 2018
CPSU-BANGHART-W18S12G2
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 4
Total : 88
