Introduction
The speaker is a crucial component of the GPS that can wear out or stop working over time. This guide will show how to properly remove it.
Position the device so that the underside is facing up. Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
  • Position the device so that the underside is facing up.
  • Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
  • Firmly grab the EasyPort Mount and remove it.
  • If it does not dislodge easily, gently twist the EasyPort Mount, applying increasing pressure until it does.
Ajouter un commentaire
Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top. Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
  • Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top.
  • Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Flip the device over so that the screen is facing up. Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
  • Flip the device over so that the screen is facing up.
  • Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
  • It may be easier to start at one of the corners.
  • The gold ribbon cable connecting the screen to the motherboard is fragile and tears easily.
  • This specific device's ribbon cable is torn.
Carefully slide the screen forward, revealing the lower portion of the motherboard. Remove the 3.6mm screw using the JIS #00 Screwdriver.
  • Carefully slide the screen forward, revealing the lower portion of the motherboard.
  • Remove the 3.6mm screw using the JIS #00 Screwdriver.
  • Rotate the device 180 degrees, carefully slide back the screen, and remove the remaining two screws.
Disconnect the battery and speaker cables. Unlatch the motherboard from the case. Unlatch the motherboard from the case.
  • Disconnect the battery and speaker cables.
  • Unlatch the motherboard from the case.
Use the pointed edge of the spudger to pop the speaker out of its compartment. The dense foam part is the speaker, not the immovable plastic.
  • Use the pointed edge of the spudger to pop the speaker out of its compartment.
  • The dense foam part is the speaker, not the immovable plastic.
  • It is more difficult to remove using the plastic opening tool, but it can still be done.
Jennifer Zakaria
Membre depuis le 18/01/2018
531 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S12-G2, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S12-G2, Banghart Winter 2018
CPSU-BANGHART-W18S12G2
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 76
