Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
  • Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
Ajouter un commentaire
Unscrew the two T5 screws using the T5 Torx Screwdriver.
  • Unscrew the two T5 screws using the T5 Torx Screwdriver.
Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
  • Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
  • Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
Remove the screen from of the face-plate.
  • Remove the screen from of the face-plate.
Insert the new screen into the face-plate.
  • Insert the new screen into the face-plate.
Reattach the yellow ribbon cable to the motherboard.
  • Reattach the yellow ribbon cable to the motherboard.
Using two hands, hold both ends of the device and snap the two plates together.
  • Using two hands, hold both ends of the device and snap the two plates together.
Re-insert the two T5 screws and tighten.
  • Re-insert the two T5 screws and tighten.
Re-apply the label edges back down to cover the screws.
  • Re-apply the label edges back down to cover the screws.
2 autre(s) ont terminé cette réparation.
Mike Sollars
Membre depuis le 11/07/2013
471 Réputation
3 tutoriels rédigés
Équipe
WRI115, Team 1-1, Ruszkiewicz Spring 2013 Membre de l'équipe WRI115, Team 1-1, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G1
4 membres
3 tutoriels rédigés
Hi! Thanks for doing this. How do I release the yellow cable from the board?
Shaun B - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 1,302
