Aller au contenu principal
Tomado Rechargeable Vacuum Cleaner Disassembly
Ce dont vous avez besoin
  1. Tomado Rechargeable Vacuum Cleaner Disassembly, Tomado Rechargeable Vacuum Cleaner Disassembly: étape 1, image 1 de 1
    • The full product in its original state.
  2. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 2, image 1 de 2 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 2, image 2 de 2
    • Remove the nozzle by pressing the white button on the top of the product just under the name of the brand.
  3. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 3, image 1 de 1
    • Remove the big parts that are inside of the nozzle. These parts consist of a plastic structure with a filter.
  4. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 4, image 1 de 2 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 4, image 2 de 2
    • Remove the rubber fitting from the inside of the nozzle by pulling it from the metal pieces.
    • Remove the blue switchbutton from the upper part of the nozzle by putting a momentum on the edge. After you have this signature move you can remove the brush. You can see the video for the signature move.
  5. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 6, image 1 de 3 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 6, image 2 de 3 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 6, image 3 de 3
    • Remove the blue switchbutton from the upper part of the nozzle by putting a momentum on the edge. After you have done this signature move you can remove the brush.
  6. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 7, image 1 de 1
    • Right now the whole nozzle is disassembled, except for two small steel rings. These will break if you try to remove them.
  7. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 8, image 1 de 1
    • Now the nozzle is disassembled we can start with the body.
  8. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 9, image 1 de 2 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 9, image 2 de 2
    • Remove 4 screws on the side and 1 screw on the bottom. You'll do this by crosshead screwdriver size number 1.
  9. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 10, image 1 de 2 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 10, image 2 de 2
    • Remove the black clip from the inner top side of the body.
  10. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 11, image 1 de 2 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 11, image 2 de 2
    • Remove the lid from the battery lid by sliding it and after pull it out.
  11. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 12, image 1 de 1
    • Remove the screw after removing the lid above the battery.
  12. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 13, image 1 de 3 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 13, image 2 de 3 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 13, image 3 de 3
    • Seperate the two body parts.
  13. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 14, image 1 de 2 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 14, image 2 de 2
    • Remove the turbine protector in front of the turbine.
  14. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 15, image 1 de 2 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 15, image 2 de 2
    • Pull the battery out. It still has some wires attached to it.
  15. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 16, image 1 de 2 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 16, image 2 de 2
    • Use the pliers to remove the wires from the battery.
  16. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 17, image 1 de 1
    • Pull the charge socket out of the plastic cover.
  17. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 18, image 1 de 2 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 18, image 2 de 2
    • Remove the button from the body.
  18. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 19, image 1 de 2 Tomado Rechargeable Vacuum Cleaner Disassembly: étape 19, image 2 de 2
    • Pull the button off the switch.
  19. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 20, image 1 de 1
    • Remove the last screw with a number 1 screwdriver, next to the electro motor to release the motor + turbine.
  20. Tomado Rechargeable Vacuum Cleaner Disassembly: étape 21, image 1 de 1
    • The remaining part consists of moving pieces that cannot be disassembled.
Koen Tijhuis
Membre depuis le 03/07/18
313 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 353
