Introduction
In this guide, you will learn how to disassemble the broken/damaged keyboard from the rest of the laptop as well as how to replace it. This guide will also teach you what the proper and necessary tools are for this repair.
Remove the front face plate with the plastic prying tool.
  • Remove the front face plate with the plastic prying tool.
  • Using an #1 Phillips screwdriver, unscrew and remove the two 3.8mm screws labeled B3.
Ajouter un commentaire
Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
  • Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
  • Note: This ribbon still connects the taptor to the keyboard.
  • Gently place the keyboard on top of the trackpad, keys' side down
Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop). Unscrew the screw on the metal plate that keeps the ribbon from sliding out. Gently remove the metal plate and set it aside.
  • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
  • Unscrew the screw on the metal plate that keeps the ribbon from sliding out.
  • Gently remove the metal plate and set it aside.
Using the plastic opener tools, dislodge the white ribbon connector from the two clips holding the connector. Using your fingers, pull out the white ribbon connector.
  • Using the plastic opener tools, dislodge the white ribbon connector from the two clips holding the connector.
  • Using your fingers, pull out the white ribbon connector.
Varsha Roopreddy
Membre depuis le 19/04/2013
1 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 4-17, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 4-17, Maness Spring 2013
CPSU-MANESS-S13S4G17
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 744
