Pièces
Aucune pièce nécessaire.
Make sure the device is off to prevent data loss. Slide both latches to the unlocked position to release the battery.
  • Make sure the device is off to prevent data loss.
  • Slide both latches to the unlocked position to release the battery.
  • Switch the latch on the right to reveal red. The latch on the left needs to be held.
  • Pull the battery toward you while holding the left latch.
Ajouter un commentaire
Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
Pull up on the back casing and remove it, revealing the audio/usb port. Pull up on the back casing and remove it, revealing the audio/usb port.
  • Pull up on the back casing and remove it, revealing the audio/usb port.
Remove the single 4 mm screw holding the port in place with the Phillips 00 screwdriver.
  • Remove the single 4 mm screw holding the port in place with the Phillips 00 screwdriver.
Use the plastic opening tool to disconnect the port from its power source on the laptop. This will be the wire connector with the white connection.
  • Use the plastic opening tool to disconnect the port from its power source on the laptop. This will be the wire connector with the white connection.
Remove the ribbon cable from the port to free it from the laptop.
  • Remove the ribbon cable from the port to free it from the laptop.
  • Be careful when reconnecting the ribbon cable, it can be difficult.
JRJones
Membre depuis le 19/04/2013
121 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 2-19, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 2-19, Maness Spring 2013
CPSU-MANESS-S13S2G19
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 748
