Aller au contenu principal
Toshiba SD-K740 Front Flap Tray Door Spring Replacement
Ce dont vous avez besoin
  1. Toshiba SD-K740 Front Flap Tray Door Spring Replacement, Top Panel: étape 1, image 1 de 1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: étape 2, image 1 de 2 Toshiba SD-K740 Front Flap Tray Door Spring Replacement: étape 2, image 2 de 2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: étape 3, image 1 de 1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Front Flap Tray Door Spring Replacement, Front Panel: étape 4, image 1 de 1
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: étape 5, image 1 de 1
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: étape 6, image 1 de 2 Toshiba SD-K740 Front Flap Tray Door Spring Replacement: étape 6, image 2 de 2
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Front Flap Tray Door Spring Replacement, Front Flap Tray Door: étape 7, image 1 de 2 Toshiba SD-K740 Front Flap Tray Door Spring Replacement, Front Flap Tray Door: étape 7, image 2 de 2
    • On back side of front panel very carefully apply pressure to the left hand side of the flap hinge.
    • There is just enough tolerance in the plastic to allow removal, be careful of brittle plastic.
  8. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: étape 8, image 1 de 1
    • Once the peg is free from the left restraint, carefully remove the left part of the flap.
    • Carefully remove the right peg from the restraint.
    • Do not pull away from the front panel because the spring is still attached.
    • Do not force the plastic.
  9. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: étape 9, image 1 de 1
    • Remove the spring from the end of the right peg by pulling the door away from the spring.
    • Do not pull away from the front panel until the spring has been removed from the flap.
  10. Toshiba SD-K740 Front Flap Tray Door Spring Replacement, Front Flap Tray Door Spring: étape 10, image 1 de 1
    • Remove the .384 inch screw holding the spring to front panel.
  11. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: étape 11, image 1 de 2 Toshiba SD-K740 Front Flap Tray Door Spring Replacement: étape 11, image 2 de 2
    • Slide the spring off of the underlying peg.
John Lokker
Membre depuis le 01/20/11
324 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 1-16, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 membres
8 tutoriels rédigés
5 commentaires
Thanks for sharing,
It's very informative for me, I really enjoy this content.
I also have Content about <a href="https://accesssecuritygates.com/"> door spring replacement</a>
Cheers.
ali - Réponse
Great Article's content. Its worth reading. What type of auto gate repair is best for you? Find out by comparing repair services, prices and tech info. If you're in need of automatic gate repair, <a href="https://www.ozgaragedoorsandgates.com/"#...>Oz Garage Doors And Gates</a> can be a solution.
ozee garage - Réponse
I got wonderful content after reading your article. Thankyou for information. Find out by comparing repair services, prices and tech info. If you're in need of automatic gate repair, <a href="http://elitecommercialgaterepairs.com/"#/>Elite Commercial Gate Repairs</a> can be a solution.
nature nut - Réponse
Thanks for this Article! If anyone looking for a platform which provide services of repairing ad installation doors. <a href="https://http://powermastergateopenerrepair.com/"...>Power Master Gate Opener Repair Specialist</a> can be a solution.
georgia oscar - Réponse
Thanks for sharing us this informative article. If you're in need of automatic gate repair, <a href="https://http://miamioverheadgaterepair.com/"#/>Miami Overhead Gate Repair</a> can be a solution.
Ella Swan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 20
Total : 5,198
