Aller au contenu principal
Toshiba SD-K740 Motherboard Fuse Replacement
Ce dont vous avez besoin
  1. Toshiba SD-K740 Motherboard Fuse Replacement, Top Panel: étape 1, image 1 de 1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Motherboard Fuse Replacement: étape 2, image 1 de 2 Toshiba SD-K740 Motherboard Fuse Replacement: étape 2, image 2 de 2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Motherboard Fuse Replacement: étape 3, image 1 de 1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Motherboard Fuse Replacement, Motherboard Fuse: étape 4, image 1 de 2 Toshiba SD-K740 Motherboard Fuse Replacement, Motherboard Fuse: étape 4, image 2 de 2
    • Using the plastic opening tool, gently pop the fuse out of its restraining brackets.
John Lokker
Membre depuis le 01/20/11
324 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 1-16, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 3,842
