Introduction
Ordered a new battery? Have no idea where to start? Well don't worry, this guide will show you how. (Part number should be PA3534U-1BRS) Don't forget to dispose the old battery in an e-waste container.
Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you. Find the battery compartment. Slide the left slider which is just beneath the battery compartment into its leftmost position.
  • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
  • Find the battery compartment.
  • Slide the left slider which is just beneath the battery compartment into its leftmost position.
Ajouter un commentaire
Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment. Do not touch the gold nodes inside the compartment. Do not touch the gold nodes inside the compartment.
  • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
  • Do not touch the gold nodes inside the compartment.
2 autre(s) ont terminé cette réparation.
Grace Cowell
Membre depuis le 15/04/2013
262 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 4-12, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 4-12, Maness Spring 2013
CPSU-MANESS-S13S4G12
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 711
