Introduction
This guide provides step by step instructions of how to replace a faulty optical drive.
Pièces
Aucune pièce nécessaire.
Flip the laptop over so the bottom is facing up.
  • Flip the laptop over so the bottom is facing up.
  • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
Ajouter un commentaire
Gently lift the battery out of the computer.
  • Gently lift the battery out of the computer.
Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
Remove the WIFI module cover. It will pull right off.
  • Remove the WIFI module cover. It will pull right off.
Unplug the white and black wires from the WiFi module. Unplug the white and black wires from the WiFi module.
  • Unplug the white and black wires from the WiFi module.
Remove the twelve 8mm button head Phillips #00 B8 screws.
  • Remove the twelve 8mm button head Phillips #00 B8 screws.
  • Remove the two 14 mm button head Phillips #00 B14 screws.
  • Remove the two 10 mm Phillips #00 battery compartment screws.
  • Remove the two 8 mm Phillips #00 screws.
Remove the seven 4mm flat Phillips #00 screws.
  • Remove the seven 4mm flat Phillips #00 screws.
  • Remove the seven 20mm button head Phillips #00 screws.
Use the plastic opening tool to pry the two halves apart.
  • Use the plastic opening tool to pry the two halves apart.
Orient the bottom assembly as displayed.
  • Orient the bottom assembly as displayed.
Remove the two 3 mm Phillips #00 screws. Remove the two 3 mm Phillips #00 screws.
  • Remove the two 3 mm Phillips #00 screws.
Slide the optical drive out of the laptop through the opening on the left side of the bottom assembly.
  • Slide the optical drive out of the laptop through the opening on the left side of the bottom assembly.
Geoff Wacker
Membre depuis le 30/09/2013
67 741 Réputation
140 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 599
