Introduction
This is a step by step guide of how to replace the speakers in case of malfunction or upgrade.
Pièces
Aucune pièce nécessaire.
Flip the laptop over so the bottom is facing up.
  • Flip the laptop over so the bottom is facing up.
  • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
Ajouter un commentaire
Gently lift the battery out of the computer.
  • Gently lift the battery out of the computer.
Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
Remove the WIFI module cover. It will pull right off.
  • Remove the WIFI module cover. It will pull right off.
Unplug the white and black wires from the WiFi module. Unplug the white and black wires from the WiFi module.
  • Unplug the white and black wires from the WiFi module.
Remove the twelve 8mm button head Phillips #00 B8 screws.
  • Remove the twelve 8mm button head Phillips #00 B8 screws.
  • Remove the two 14 mm button head Phillips #00 B14 screws.
  • Remove the two 10 mm Phillips #00 battery compartment screws.
  • Remove the two 8 mm Phillips #00 screws.
Remove the seven 4mm flat Phillips #00 screws.
  • Remove the seven 4mm flat Phillips #00 screws.
  • Remove the seven 20mm button head Phillips #00 screws.
Use the plastic opening tool to pry the two halves apart.
  • Use the plastic opening tool to pry the two halves apart.
Locate the plug for the speaker wires on the bottom of the laptop. Locate the plug for the speaker wires on the bottom of the laptop.
  • Locate the plug for the speaker wires on the bottom of the laptop.
Unplug the speaker wire connector.
  • Unplug the speaker wire connector.
Remove the speakers by sliding them straight up. They should slide out with ease.
  • Remove the speakers by sliding them straight up. They should slide out with ease.
Cole Uhland
Membre depuis le 30/09/2013
216 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 14-8, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 14-8, Forte Fall 2013
CPSU-FORTE-F13S14G8
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 305
