Aller au contenu principal
Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: étape 1, image 1 de 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: étape 1, image 2 de 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: étape 1, image 3 de 3
    • Switch-off the laptop and remove the battery.
    • Use cutter and plastic tool to remove the Keyboard, held by 7x locking clips.
  2. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: étape 2, image 1 de 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: étape 2, image 2 de 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: étape 2, image 3 de 3
    • Remove 7x screws from the upper case.
    • Disassemble the HDD, RAM Memory cover and remove the HDD (just for safety).
    • Then remove 12x screws so you can start with disassembling the bottom case.
  3. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: étape 3, image 1 de 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: étape 3, image 2 de 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: étape 3, image 3 de 3
    • Use a plastic tool for separating the bottom case from the laptop.
  4. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: étape 4, image 1 de 2 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: étape 4, image 2 de 2
    • Here is the WiFi, Bluetooth half mini PCIe card.
    • Disconnect 2x antenna cables (luetooth and WiFi).
    • The mini PCI card is held by one small screw.
    • Did you do it successfully?
5 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 341 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 541 tutoriels rédigés
3 commentaires
This card is mini pcie (express) not mini pci. A small quibble but it did cause me to waste time looking at it.
mknoy - Réponse
You're right, my mistake.
ZFix -
This is a great explanation (exactly what I would have done), but I’m unable to find info on which pcie WiFi cards are compatible with C850. I want to install a 2400Mbps card, but uncertain if it will be compatible. Do you have any info/advice on this?
Matthew Rummins - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 20
30 derniers jours : 63
Total : 8,080
