Aller au contenu principal
Toshiba Satellite E105-S1602 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite E105-S1602 Keyboard Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite E105-S1602 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Slide both of the latches to the outside to release the battery.
  2. Toshiba Satellite E105-S1602 Keyboard Replacement: étape 2, image 1 de 2 Toshiba Satellite E105-S1602 Keyboard Replacement: étape 2, image 2 de 2
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: étape 3, image 1 de 3 Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: étape 3, image 2 de 3 Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: étape 3, image 3 de 3
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Toshiba Satellite E105-S1602 Keyboard Replacement: étape 4, image 1 de 2 Toshiba Satellite E105-S1602 Keyboard Replacement: étape 4, image 2 de 2
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. Toshiba Satellite E105-S1602 Keyboard Replacement: étape 5, image 1 de 2 Toshiba Satellite E105-S1602 Keyboard Replacement: étape 5, image 2 de 2
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Toshiba Satellite E105-S1602 Keyboard Replacement: étape 6, image 1 de 1
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Toshiba Satellite E105-S1602 Keyboard Replacement: étape 7, image 1 de 1
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Toshiba Satellite E105-S1602 Keyboard Replacement: étape 8, image 1 de 2 Toshiba Satellite E105-S1602 Keyboard Replacement: étape 8, image 2 de 2
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
Ian Washburne
Membre depuis le 01/11/13
59 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 17-21, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 1,552
