Introduction
The WiFi card is what assists your device with connecting to the internet without an Ethernet cable. If nothing is wrong with the router that you are trying to connect with then you may need to replace your WiFi card.
Slide both of the latches to the outside to release the battery. Slide both of the latches to the outside to release the battery.
  • Slide both of the latches to the outside to release the battery.
Ajouter un commentaire
Pull the battery out by lifting the battery cover away from the laptop. Pull the battery out by lifting the battery cover away from the laptop.
  • Pull the battery out by lifting the battery cover away from the laptop.
Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard. Pry the top plastic strip from the top of the keyboard. Peel the strip completely away from the keyboard.
  • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
  • Pry the top plastic strip from the top of the keyboard.
  • Peel the strip completely away from the keyboard.
Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard. Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it. Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
  • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half. Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
  • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
  • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
Locate the four silver screws on the front panel. Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
  • Locate the four silver screws on the front panel.
  • Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
Flip the laptop over and locate all seven screws on the bottom of the laptop. Unscrew all seven Philips#00 7.70mm screws.
  • Flip the laptop over and locate all seven screws on the bottom of the laptop.
  • Unscrew all seven Philips#00 7.70mm screws.
Locate and unscrew the three silver Philips #00 2.85mm screws inside the battery compartment. Locate and unscrew the five black Philips #00 3.25mm screws inside the battery compartment.
  • Locate and unscrew the three silver Philips #00 2.85mm screws inside the battery compartment.
  • Locate and unscrew the five black Philips #00 3.25mm screws inside the battery compartment.
Rotate the laptop so the back faces you. Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
  • Rotate the laptop so the back faces you.
  • Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
Use the plastic opening tool to pry the top panel up from the base of the computer. Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base. Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
  • Use the plastic opening tool to pry the top panel up from the base of the computer.
  • Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
  • Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
  • Disconnect ribbons, and slowly lift the top panel up, away from the base.
Locate the ribbon cable from the motherboard. Using plastic removing tools, pop the ribbon base from the motherboard.
  • Locate the ribbon cable from the motherboard.
  • Using plastic removing tools, pop the ribbon base from the motherboard.
Locate the two plugs from the motherboard. Using plastic opening tools, remove each plug from the motherboard.
  • Locate the two plugs from the motherboard.
  • Using plastic opening tools, remove each plug from the motherboard.
Locate the ribbon cable partially hidden under the front panel. Using plastic opening tools, pop out the ribbon cable from the motherboard.
  • Locate the ribbon cable partially hidden under the front panel.
  • Using plastic opening tools, pop out the ribbon cable from the motherboard.
Make sure that all wires have been disconnected before proceeding to avoid damaging components.
  • Make sure that all wires have been disconnected before proceeding to avoid damaging components.
  • Slowly lift the top panel away from the base of the computer.
  • Place the top panel away from the computer and keep in a flat non-metallic surface until needed.
Locate the WiFi card, which is directly beneath the disc drive.
  • Locate the WiFi card, which is directly beneath the disc drive.
Locate the black wire and white wire connected to the WiFi card. Using a pair of tweezers remove the wires by lifting them straight up away from the board. For reassembly, note that the black wire connects to the top port, and the white wire to the bottom part.
  • Locate the black wire and white wire connected to the WiFi card.
  • Using a pair of tweezers remove the wires by lifting them straight up away from the board.
  • For reassembly, note that the black wire connects to the top port, and the white wire to the bottom part.
Locate and remove the two Philips #00 4.85 mm screws on the left of the WiFi card. Locate and remove the two Philips #00 4.85 mm screws on the left of the WiFi card.
  • Locate and remove the two Philips #00 4.85 mm screws on the left of the WiFi card.
Be careful not to pull the WiFi card straight up, as you might damage components on the motherboard. Grip the sides of the WiFi card and lift it up partially.
  • Be careful not to pull the WiFi card straight up, as you might damage components on the motherboard.
  • Grip the sides of the WiFi card and lift it up partially.
  • Gently pull the WiFi card away from the black plastic base to remove.
Ian Washburne
Membre depuis le 11/01/2013
45 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 17-21, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 1,402
