Aller au contenu principal
Toshiba Satellite E45DW-C4210 Battery Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite E45DW-C4210  Battery  Replacement, Battery: étape 1, image 1 de 1
    • Using a Phillips #0 screwdriver, remove all nine of the screws along the outside of the bottom of the laptop.
  2. Toshiba Satellite E45DW-C4210  Battery  Replacement: étape 2, image 1 de 3 Toshiba Satellite E45DW-C4210  Battery  Replacement: étape 2, image 2 de 3 Toshiba Satellite E45DW-C4210  Battery  Replacement: étape 2, image 3 de 3
    • Using your fingers, gently loosen the outside edge of the laptop.
    • Unsnap the bottom of the case from the computer by pulling each side apart in the middle of the computer.
  3. Toshiba Satellite E45DW-C4210  Battery  Replacement: étape 3, image 1 de 2 Toshiba Satellite E45DW-C4210  Battery  Replacement: étape 3, image 2 de 2
    • Pull up the black strip of tape.
  4. Toshiba Satellite E45DW-C4210  Battery  Replacement: étape 4, image 1 de 1
    • Using your pointer finger and thumb grab the cords where they connect to the plug.
    • Gently pull the battery attachment from the laptop.
  5. Toshiba Satellite E45DW-C4210  Battery  Replacement: étape 5, image 1 de 2 Toshiba Satellite E45DW-C4210  Battery  Replacement: étape 5, image 2 de 2
    • Using the Phillips #0 screwdriver, unscrew each of the four screws holding the battery in place.
  6. Toshiba Satellite E45DW-C4210  Battery  Replacement: étape 6, image 1 de 1
    • Lift and remove the battery from the device.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 15
Total : 2,014
