Introduction
Use this guide to replace the battery in your Toshiba. If your battery is damaged or won't hold a charge, it should be replaced.
Pièces
Aucune pièce nécessaire.
Turn the laptop upside-down.
  • Turn the laptop upside-down.
  • Position the laptop so that the display hinges are facing away from you.
Ajouter un commentaire
Slide the left battery bay latch to the left.
  • Slide the left battery bay latch to the left.
Slide the right battery bay latch to the right and hold. While holding onto the latch, use a plastic opening tool to lift and remove the battery bay cover. Remove the battery.
  • Slide the right battery bay latch to the right and hold.
  • While holding onto the latch, use a plastic opening tool to lift and remove the battery bay cover.
  • Remove the battery.
Michael Erberich
Membre depuis le 17/04/2013
100 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 3-49, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
4 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 572
