Aller au contenu principal
Toshiba Satellite L305-S5946 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305-S5946 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 Keyboard Replacement: étape 2, image 1 de 1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 Keyboard Replacement: étape 3, image 1 de 3 Toshiba Satellite L305-S5946 Keyboard Replacement: étape 3, image 2 de 3 Toshiba Satellite L305-S5946 Keyboard Replacement: étape 3, image 3 de 3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 Keyboard Replacement, Hard Drive: étape 4, image 1 de 1
    • Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
  5. Toshiba Satellite L305-S5946 Keyboard Replacement: étape 5, image 1 de 2 Toshiba Satellite L305-S5946 Keyboard Replacement: étape 5, image 2 de 2
    • Lift the hard drive cover using a non-marring iFixit opening tool.
    • This will expose the hard drive.
  6. Toshiba Satellite L305-S5946 Keyboard Replacement: étape 6, image 1 de 3 Toshiba Satellite L305-S5946 Keyboard Replacement: étape 6, image 2 de 3 Toshiba Satellite L305-S5946 Keyboard Replacement: étape 6, image 3 de 3
    • Slide the hard drive to the left using your fingers.
    • Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
  7. Toshiba Satellite L305-S5946 Keyboard Replacement, RAM: étape 7, image 1 de 1
    • Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
    • This is a captive panel screw and remains with the cover.
  8. Toshiba Satellite L305-S5946 Keyboard Replacement: étape 8, image 1 de 2 Toshiba Satellite L305-S5946 Keyboard Replacement: étape 8, image 2 de 2
    • Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
  9. Toshiba Satellite L305-S5946 Keyboard Replacement: étape 9, image 1 de 2 Toshiba Satellite L305-S5946 Keyboard Replacement: étape 9, image 2 de 2
    • Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
    • The RAM card should pop up at an angle.
  10. Toshiba Satellite L305-S5946 Keyboard Replacement: étape 10, image 1 de 2 Toshiba Satellite L305-S5946 Keyboard Replacement: étape 10, image 2 de 2
    • Pull the RAM card away from the computer.
    • Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
  11. Toshiba Satellite L305-S5946 Keyboard Replacement, Keyboard: étape 11, image 1 de 1
    • Place the laptop right-side-up so the screen faces you.
  12. Toshiba Satellite L305-S5946 Keyboard Replacement: étape 12, image 1 de 3 Toshiba Satellite L305-S5946 Keyboard Replacement: étape 12, image 2 de 3 Toshiba Satellite L305-S5946 Keyboard Replacement: étape 12, image 3 de 3
    • Remove the strip of plastic at the right furthermost edge of the keyboard using a plastic opening tool.
    • Insert the plastic opening tool at either end of the strip.
    • Lift upwards and proceed to the other end while repeating this lifting process every one to two inches.
  13. Toshiba Satellite L305-S5946 Keyboard Replacement: étape 13, image 1 de 1
    • CAUTION: do not allow hardware or debris into the CPU fan and duct.
    • Remove the two 3-mm screws at the top edge of the keyboard using a Phillips #00 screwdriver.
    • These are not captive panel screws and, once loosened, will be free to move about the assembly.
  14. Toshiba Satellite L305-S5946 Keyboard Replacement: étape 14, image 1 de 2 Toshiba Satellite L305-S5946 Keyboard Replacement: étape 14, image 2 de 2
    • Pry the top of the keyboard loose from its casing using a plastic opening tool.
  15. Toshiba Satellite L305-S5946 Keyboard Replacement: étape 15, image 1 de 1
    • Gently grasp the top of the keyboard and pull it up and toward the screen.
    • CAUTION: Pulling too hard could damage the black ribbon cable under the keyboard.
  16. Toshiba Satellite L305-S5946 Keyboard Replacement: étape 16, image 1 de 3 Toshiba Satellite L305-S5946 Keyboard Replacement: étape 16, image 2 de 3 Toshiba Satellite L305-S5946 Keyboard Replacement: étape 16, image 3 de 3
    • Gently push the two tabs locking the black ribbon cable.
    • To remove the black ribbon cable from the motherboard, slide the keyboard toward the screen.
    • You may now safely separate the keyboard from the laptop.
Michael Erberich
Membre depuis le 04/17/13
130 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 3-49, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
4 membres
19 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,608
