Aller au contenu principal
Toshiba Satellite L45-S7423 RAM Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L45-S7423 RAM Replacement, Battery: étape 1, image 1 de 3 Toshiba Satellite L45-S7423 RAM Replacement, Battery: étape 1, image 2 de 3 Toshiba Satellite L45-S7423 RAM Replacement, Battery: étape 1, image 3 de 3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 RAM Replacement: étape 2, image 1 de 2 Toshiba Satellite L45-S7423 RAM Replacement: étape 2, image 2 de 2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 RAM Replacement: étape 3, image 1 de 2 Toshiba Satellite L45-S7423 RAM Replacement: étape 3, image 2 de 2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 RAM Replacement, Bottom Access Panel: étape 4, image 1 de 3 Toshiba Satellite L45-S7423 RAM Replacement, Bottom Access Panel: étape 4, image 2 de 3 Toshiba Satellite L45-S7423 RAM Replacement, Bottom Access Panel: étape 4, image 3 de 3
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 RAM Replacement: étape 5, image 1 de 3 Toshiba Satellite L45-S7423 RAM Replacement: étape 5, image 2 de 3 Toshiba Satellite L45-S7423 RAM Replacement: étape 5, image 3 de 3
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 RAM Replacement, RAM: étape 6, image 1 de 3 Toshiba Satellite L45-S7423 RAM Replacement, RAM: étape 6, image 2 de 3 Toshiba Satellite L45-S7423 RAM Replacement, RAM: étape 6, image 3 de 3
    • Pull apart the two tabs holding the RAM in place.
  7. Toshiba Satellite L45-S7423 RAM Replacement: étape 7, image 1 de 1
    • Upon release, RAM will automatically pop up.
  8. Toshiba Satellite L45-S7423 RAM Replacement: étape 8, image 1 de 3 Toshiba Satellite L45-S7423 RAM Replacement: étape 8, image 2 de 3 Toshiba Satellite L45-S7423 RAM Replacement: étape 8, image 3 de 3
    • Gently pull on RAM to remove.
Stephen Sippel
Membre depuis le 04/16/13
194 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 21-54, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 1,541
