Aller au contenu principal
Toshiba Satellite L455-S5975 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L455-S5975 Keyboard Replacement, Keyboard: étape 1, image 1 de 2 Toshiba Satellite L455-S5975 Keyboard Replacement, Keyboard: étape 1, image 2 de 2
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Toshiba Satellite L455-S5975 Keyboard Replacement: étape 2, image 1 de 1
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Toshiba Satellite L455-S5975 Keyboard Replacement: étape 3, image 1 de 1
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  4. Toshiba Satellite L455-S5975 Keyboard Replacement: étape 4, image 1 de 2 Toshiba Satellite L455-S5975 Keyboard Replacement: étape 4, image 2 de 2
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
Mike Kennedy
Membre depuis le 04/18/13
160 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 2-21, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 2-21, Maness Spring 2013
CPSU-MANESS-S13S2G21
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 2,360
