Aller au contenu principal
Toshiba Satellite L505D-GS6000 Disk Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: étape 1, image 2 de 2
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: étape 2, image 1 de 1
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Disk Drive: étape 3, image 1 de 1
    • Remove the M2 5x6 mm screw pointed out in the picture using the Phillips #0 screwdriver.
    • You do not need to remove anything else in order to take out the disk drive.
  4. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: étape 4, image 1 de 1
    • Gently slide the disk drive out to the right until it is removed from the computer.
    • If the disk drive doesn’t easily slide out then there is possible damage on the inside of the laptop.
Adam Dellicker
Membre depuis le 03/19/18
539 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G2, Covino Spring 2018 Membre de l'équipe UMass Dartmouth, Team S4-G2, Covino Spring 2018
UMASSD-COVINO-S18S4G2
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 349
