Aller au contenu principal
Toshiba Satellite L55t-B5271 Motherboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L55t-B5271 Motherboard Replacement, Battery: étape 1, image 1 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement, Battery: étape 1, image 2 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement, Battery: étape 1, image 3 de 3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 2, image 1 de 2 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 2, image 2 de 2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 3, image 1 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 3, image 2 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 3, image 3 de 3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Motherboard Replacement, Back Panel: étape 4, image 1 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement, Back Panel: étape 4, image 2 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement, Back Panel: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    J'achète
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 Motherboard Replacement, RAM: étape 5, image 1 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement, RAM: étape 5, image 2 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement, RAM: étape 5, image 3 de 3
    • This laptop does not have a RAM present. Follow instructions to replace your own.
    • Evenly press down on the clips on either side of the RAM stick.
    • To pull out the RAM stick, be sure to align the notches on the RAM stick with the notches in the RAM holder.
  6. Toshiba Satellite L55t-B5271 Motherboard Replacement, Wireless Card: étape 6, image 1 de 2 Toshiba Satellite L55t-B5271 Motherboard Replacement, Wireless Card: étape 6, image 2 de 2
    • Remove the ribbon by flipping up the tabs and using the black tweezers to gently pull the ribbon out from both ends.
  7. Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 7, image 1 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 7, image 2 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 7, image 3 de 3
    • Remove the tape from the card.
    • Disconnect the wires using the #4 black spudger tool.
  8. Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 8, image 1 de 1
    • Remove the 3mm Phillips head screw with a Phillips #00 screwdriver.
  9. Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 9, image 1 de 2 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 9, image 2 de 2
    • Pull up on the wireless card and remove it from the device.
  10. Toshiba Satellite L55t-B5271 Motherboard Replacement, CD Drive: étape 10, image 1 de 2 Toshiba Satellite L55t-B5271 Motherboard Replacement, CD Drive: étape 10, image 2 de 2
    • Remove the 3 mm Philips head screw that connects the CD drive to motherboard with a Phillips #00 screwdriver.
  11. Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 11, image 1 de 2 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 11, image 2 de 2
    • Gently pull the CD drive out, disconnecting it from the motherboard connector marked in blue.
  12. Toshiba Satellite L55t-B5271 Motherboard Replacement, Cooling Fan with Heat Sink: étape 12, image 1 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement, Cooling Fan with Heat Sink: étape 12, image 2 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement, Cooling Fan with Heat Sink: étape 12, image 3 de 3
    • The ribbon and wire must be moved out of the way of the fan.
    • Using a black tweezer tool, lift the tab holding the ribbon in place and then gently pull it out.
    • Using the same tweezer tool, again lift the tab holding the wires in place and gently pull them out.
  13. Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 13, image 1 de 2 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 13, image 2 de 2
    • Unscrew the two 3mm Phillips head screws on each fan using the Phillips #00 screwdriver.
  14. Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 14, image 1 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 14, image 2 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 14, image 3 de 3
    • Unscrew the four, 3mm Phillips head screws holding the last piece to the laptop using a Phillips #00 screwdriver.
    • Gently pull the cooling fan with heat sink off the laptop and set aside.
  15. Toshiba Satellite L55t-B5271 Motherboard Replacement, Motherboard: étape 15, image 1 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement, Motherboard: étape 15, image 2 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement, Motherboard: étape 15, image 3 de 3
    • Disconnect all of the ribbons by lifting the tabs and gently pulling them out.
  16. Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 16, image 1 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 16, image 2 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 16, image 3 de 3
    • Remove the wires from the motherboard using the tweezers.
  17. Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 17, image 1 de 1
    • Remove all seven of the 3mm Phillips head screws with the Phillips #00 screwdriver.
  18. Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 18, image 1 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 18, image 2 de 3 Toshiba Satellite L55t-B5271 Motherboard Replacement: étape 18, image 3 de 3
    • Gently lift the motherboard from the back of the laptop.
Noelle Dulude
Membre depuis le 03/19/18
480 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G3, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G3, Peak Spring 2018
UMASSD-PEAK-S18S3G3
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 818
