Introduction
This guide will help you to remove your broken RAM and replace it with a new one. Since the RAM is frequently updated to ensure top performance, the RAM is very easy to replace.
Make sure you turn the laptop off first. Close the laptop lid and flip it over so that Toshiba logo is facing down. Close the laptop lid and flip it over so that Toshiba logo is facing down.
  • Make sure you turn the laptop off first.
  • Close the laptop lid and flip it over so that Toshiba logo is facing down.
Ajouter un commentaire
Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver. Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Once the screws are removed, slide the battery pack out of the computer. Once the screws are removed, slide the battery pack out of the computer. Once the screws are removed, slide the battery pack out of the computer.
  • Once the screws are removed, slide the battery pack out of the computer.
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver. Use the plastic opening tool to remove the back cover from the laptop. Be aware that static discharge can cause damage to sensitive electrical components within the computer.  To avoid this you can wear an anti-static wrist strap.
  • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
  • Use the plastic opening tool to remove the back cover from the laptop.
  • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
This laptop does not have a RAM present. Follow instructions to replace your own. Evenly press down on the clips on either side of the RAM stick. To pull out the RAM stick, be sure to align the notches on the RAM stick with the notches in the RAM holder.
  • This laptop does not have a RAM present. Follow instructions to replace your own.
  • Evenly press down on the clips on either side of the RAM stick.
  • To pull out the RAM stick, be sure to align the notches on the RAM stick with the notches in the RAM holder.
Carson Longendorfer
Membre depuis le 26/03/2018
205 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G3, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G3, Peak Spring 2018
UMASSD-PEAK-S18S3G3
3 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 47
