Aller au contenu principal
Toshiba Satellite L55t-B5271 Screen Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L55t-B5271 Screen Replacement, Battery: étape 1, image 1 de 3 Toshiba Satellite L55t-B5271 Screen Replacement, Battery: étape 1, image 2 de 3 Toshiba Satellite L55t-B5271 Screen Replacement, Battery: étape 1, image 3 de 3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Screen Replacement: étape 2, image 1 de 2 Toshiba Satellite L55t-B5271 Screen Replacement: étape 2, image 2 de 2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Screen Replacement: étape 3, image 1 de 3 Toshiba Satellite L55t-B5271 Screen Replacement: étape 3, image 2 de 3 Toshiba Satellite L55t-B5271 Screen Replacement: étape 3, image 3 de 3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Screen Replacement, Back Panel: étape 4, image 1 de 3 Toshiba Satellite L55t-B5271 Screen Replacement, Back Panel: étape 4, image 2 de 3 Toshiba Satellite L55t-B5271 Screen Replacement, Back Panel: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    J'achète
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 Screen Replacement, Screen: étape 5, image 1 de 3 Toshiba Satellite L55t-B5271 Screen Replacement, Screen: étape 5, image 2 de 3 Toshiba Satellite L55t-B5271 Screen Replacement, Screen: étape 5, image 3 de 3
    • Unscrew the four 6mm screws from each of the laptop hinges using a Philips head #00 screwdriver.
  6. Toshiba Satellite L55t-B5271 Screen Replacement: étape 6, image 1 de 3 Toshiba Satellite L55t-B5271 Screen Replacement: étape 6, image 2 de 3 Toshiba Satellite L55t-B5271 Screen Replacement: étape 6, image 3 de 3
    • Disconnect connect the ribbon marked in red.
    • Disconnect all ribbons and cables marked in orange.
  7. Toshiba Satellite L55t-B5271 Screen Replacement: étape 7, image 1 de 1
    • Flip your laptop back to the front.
    • Lift up the screen cover.
  8. Toshiba Satellite L55t-B5271 Screen Replacement: étape 8, image 1 de 2 Toshiba Satellite L55t-B5271 Screen Replacement: étape 8, image 2 de 2
    • Gently pull the screen to disconnect the monitor from the hinges.
  9. Toshiba Satellite L55t-B5271 Screen Replacement: étape 9, image 1 de 3 Toshiba Satellite L55t-B5271 Screen Replacement: étape 9, image 2 de 3 Toshiba Satellite L55t-B5271 Screen Replacement: étape 9, image 3 de 3
    • Use the plastic opening tool to pry the plastic covering off of the monitor.
    • Be careful not to break the glass, as this can cause injury.
  10. Toshiba Satellite L55t-B5271 Screen Replacement: étape 10, image 1 de 3 Toshiba Satellite L55t-B5271 Screen Replacement: étape 10, image 2 de 3 Toshiba Satellite L55t-B5271 Screen Replacement: étape 10, image 3 de 3
    • Remove the four 3mm Phillips head screws with a Phillips #00 screwdriver.
    • Gently remove the screen from the device.
2 autres ont terminé cette réparation.
Carson Longendorfer
Membre depuis le 03/26/18
274 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G3, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G3, Peak Spring 2018
UMASSD-PEAK-S18S3G3
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 1,435
